Is this build good?
424 Views 4 Replies 4 Participants Last post by  StrongmanSal
Hi,
I've selected all components and wanted to ask if you could check if they are all compatible and good choices, especially for overclocking. Here is a screen with the hardware of the site I want to order from. Thanks a lot.
http://www.bilder-space.de/show.php?...2nkR6Tefqu.JPG
Since hardware is quite pricey here it costs about 1960€(2955.40$).
The computer should be able to handle todays games on one 24" 1920x1200 monitor on maximum settings. I want to overclock the cpu and the gpu as far as possible(with air cooling) and consider buying a second HD 5970 for crossfire when prices decrease. I may also add more HDDs and optical drives in the future.
CPU: Intel Core i7-920 Tray 8192Kb, LGA1366
CPU Cooler: Arctic Freezer xtreme Rev 2.0
Mainboard: ASUS Rampage II Extreme
HDD: (two)Samsung SpinPoint F3 1000GB, SATA II (HD103SJ) for RAID 0
Graphic: MSI R5970-P2D2, 2048MB, PCI-Express
DVD Burner: LG GH22NS50 bare
RAM: 12GB-6x-Kit Corsair XMS3 PC1600 CL8 Dominator "with Airflow"
PSU: Corsair HX1000W 1000 Watt
Case: Coolermaster ATC 840
1 - 5 of 5 Posts
Well I think you could get another brand of RAM, maybe a Mega or true for CPU cooler...Maybe a EVGA classified instead of the Asus for your motherboard....
Is something wrong with Corsair or Asus? Last time i checked they were great brands.
Nope nothing at all... but I mean do you really need corsair dominator memory, when u can get the same performance from another company? The classified is a great board and is less expensive than the Asus board.. thats all I was pointing out.
1 - 5 of 5 Posts
