Is this good?
889 14
Please tell me if this is good, and if not, what can I do about it?
1 - 15 of 15 Posts
...huh?
You'll need to give more information. Post the first tab on your CPU-Z window also, so we see. Also, what do you mean by 'good'?
Originally Posted by RubberDucky
EDIT- nevermind i missread cpuz the timinngs are great
...his RAM is underclocked, how are those great timings. Like I said in my post, there's not enough information to make any sort of judgement.
Discussion Starter · #8 ·
Ok, umm well how do i bring it back to stock timings? I never touched anything, idt.
Discussion Starter · #11 ·
Ok, one does the 1:1 thing mean that they are to be both at 200mhz, or what? And second, I don't think that my bios has a divider setting. Can you help plz?
Dont bump so soon. Patience. Anyways, you may need to enable it.. Do you see anything where it says like RAM or Memory "133, 200, 333, 400"? If so, set it to 400 and up your memory voltage smallest it can if you havent already.
Discussion Starter · #14 ·
Ok, thanks will try that. Also I got a program that came with the mobo, it overclocks CPU, RAM, PCI, and what not. Should I uninstall it?
Discussion Starter · #15 ·
I was reading another forum, and one guy had almost the EXACT same problem as me, and he said what was wrong was, he needed bios updates, does this make sense?
1 - 15 of 15 Posts
