1 - 9 of 9 Posts
There is a large difference between my core temperatures for some reason. The CPU cooler is fastened tightly and I applied Arctic Cooling MX-2 the same way I always do. This is a brand new CPU I just bought today, but should I be seeing such a large difference in the core temperatures?
Thanks.
Discussion Starter · #6 ·
I just re-seated today and my second core is still a few degrees hotter than my first core, and at load its warmer by several degrees. Both cores do not exceed 50C at load either way, and this is at 1.3v @ 4.00 GHz
If you have reseated and see similar results I wouldn't sweat it, especially if your temps are under control.
1 - 9 of 9 Posts
