1 - 17 of 17 Posts
I am just wondering if this system process is normal to have at startup? I never noticed it before and my PC has been restarting all the sudden.<br><a href="http://assets.overclock.net.s3.amazonaws.com/1/11/111eb78a_vbattach33692.jpeg"><img src="http://www.overclock.net/image/id/616687/width/525/height/525/flags/LL"></a>
Lol <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
Its a VERY normal process. Some thing else is causing your restarts. Maybe Memory, Spyware, powerbox issue, motherboard problem etc. I think we need a bit more info.
Reactions: Villainstone
Nope, thats fine. What are your temps like? That can often cause restarts. Also scan for spyware and virus's.
Discussion Starter #4
Well I believe that my temps are ok but the MB is a bit warmer than usual. I was thinking hardware too at first but I can seem to figure out what I did any different. It actually just started today or at least thats the first time I noticed. I guess spyware may be the culprit I haven't ran one in a while.<br><a href="http://assets.overclock.net.s3.amazonaws.com/d/d1/d1c61657_vbattach33693.jpeg"><img src="http://www.overclock.net/image/id/616686/width/525/height/525/flags/LL"></a>
Well, temps look fine unless it is reading them wrong. Go into bios and see what temperature that reads. And yes, I would run some spyware checks.
Discussion Starter #6
That program reads from the BIOS, whatever thats says is what the BIOS says. The BIOS is wrong about those 3.3v rails though, I had a MM hooked up for an hour and the volts were fine. I switched to the 12v rail and alls well there to.
If the virus/spyware scan does not work then put memtest86 on a cd. Boot it and let it do all the tests 20 times. (Might want to leave it on overnight).
Discussion Starter #8
Yeah I will run memtest as soon as I am done with all the scans. I did come up with some trojans on a few other things hopefully its all fixed after this.
<tr>
<div>
Originally Posted by <strong>Villainstone</strong>
</div>
<div style="font-style:italic">Yeah I will run memtest as soon as I am done with all the scans. I did come up with some trojans on a few other things hopefully its all fixed after this.</div>
</td>
</tr>
</table>
</div>"Some" Trojans as in more than one. In future you seriously will need to keep a tighter grip on your security. A trojan means some one else could of taken complete control of your computer.
I can't help but notice the '68 blocked popups'. That tells me something isn't too right there lol. Definitely a Spyware/ Adware issue.
i dont know if you know this but, if u go 2 google and type in a system process it will tell u what it is, weather it be spy ware or a crucial system process it wil tell u<br><br>
edit: i have found a few that way
<div>Originally Posted by <strong>MindOfChaos</strong></div>
<div style="font-style:italic;">"Some" Trojans as in more than one. In future you seriously will need to keep a tighter grip on your security. A trojan means some one else could of taken complete control of your computer.</div>
</td>
</tr></table></div>
99/100 viruses that people get are trojans - most are pretty harmless. most of the time the trojan is just something that dl's spyware etc - not a hijack attempt.<br><br>
don't worry too much if you have a trojan or two. if your av starts kicking out virii that aren't trojans - now you should worry
<div>Originally Posted by <strong>Kimon</strong></div>
<div style="font-style:italic;">I can't help but notice the '68 blocked popups'. That tells me something isn't too right there lol. Definitely a Spyware/ Adware issue.</div>
</td>
</tr></table></div>
On the google bar, it tallies up all the blocked popups in the time you have had it installed. 68 isnt nessesarily that many, unless they changed how it works.
Umm... I don't see whats wrong with the picture.<br><br>
System Idle Process is <b>supose</b> to have a high number under the CPU section when the system is idle, that means its not doing anything. When SIP is 0% or something that means that your CPU is at load. If you look at the bottem of the task manager it shows that the CPU Usage is 0% <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #15
well I cleaned out all the infectious crap and it is still restarting. I am about to tear it all apart and see how that works. When I ran memtest86+ after about 45mins my PC restarted but no error's were reported. It just kept restarting even after I returned everything to stock.
I've read that scvhost.exe can be used as malware... I noticed you have 2 instances running in SYSTEM.
Discussion Starter #17
If I dont have it then I restart anyway.<br><br>
EDIT: Sorry I only had like 50 seconds to right that. Anyway if I try to end the process then it restarts my PC. I have like 4 instances of this svchost.exe thing and none of my scanners picked it up. I used Ad-Aware, Spybot S&D, and Advanced windows care 2, and for virus scanner I use Avast and they are all updated.<br><br>
I just did a hardware seating, I took out most of my components and put them back in snug, I also reseated all my cables so I hope all will be well here this time so far so good.
1 - 17 of 17 Posts
