1 - 10 of 10 Posts
A bit too close, AMD official "requirement is 700W" plus - the TT unit is OK but far from a "quality" unit.
Senior OCN Member
Discussion Starter #5
Thanks for all your input, can anyone recommend a suitable one that is under £90? It also needs to be modular as well or the half modular as its in a Mini ITX system so space is precious
Senior OCN Member
The 550 watt EVGA SuperNova G2 can be had for around £70-75 on Amazon and Scan.
https://www.amazon.co.uk/EVGA-SuperNova-Fully-Modular-Supply/dp/B0141B21JG/ref=sr_1_1?ie=UTF8&qid=1461331727&sr=8-1&keywords=EVGA+SuperNova+G2+550
https://www.scan.co.uk/search.aspx?q=EVGA+SuperNova+G2+
The Corsair RMx is priced in the same price range
https://www.amazon.co.uk/Corsair-CP-9020090-UK-RM550X-Modular-Supply/dp/B015PWMRI0/ref=sr_1_1?ie=UTF8&qid=1461331856&sr=8-1&keywords=Corsair+RMx+550
https://www.scan.co.uk/search.aspx?q=Corsair+RMx+550
https://www.overclockers.co.uk/corsair-rm-series-rm550x-80-gold-550w-modular-power-supply-cp-9020090-uk-ca-208-cs.html
http://www.novatech.co.uk/products/components/powersupplies/451wto650w/cp-9020090-uk.html
Both are about as good so just get whatever you like the most.
Discussion Starter #7
Just makes me wonder as I know wattage isnt anything over quality but shouldn't i really look to increase or have a similar wattage power supply?
Senior OCN Member
You dont need more wattage unless you are going to add another card later and do a crossfire setup, or if you are going to mess around with BIOS volt mods.
More wattage is not better so get quality instead of wattage you dont need.
Reactions: Rebellion88
Aint da way it used to be
Also, keep in mind that PSUs have an optimal running load. They will run most efficient at a certain percentage of load. Having way more watts than you need, means you will be running less efficiently.
Discussion Starter #10
Thanks for your help, at the moment I plan to grab a AMD 390X unless I can grab a great deal on a Nvidia 980, but we will see.
1 - 10 of 10 Posts
