Ryzen 5600X, MSI Mag B550M Mortar, Ballistix 2x16GB Micron E, Gigabyte Aorus 3080 Master
I just picked up some used ram from eBay. I should have done a little more research but the G Skill code 8810B indicated it should be B die. The sticks appear to be from September 2017.
Here's the Thaiphoon readout. Both sticks seem to have CRC errors in their SPD tables which I read shouldn't be a huge deal. What is confusing me is the part number is K4A8G085W[B/C]? Shouldn't it just be one or the other to indicate B or C die?
Here's the ZenTimings with XMP @ 3200
I'm currently running TM5 with anta777 extreme (15 minutes in and no errors so far) to see if running a tRFC of 320 (200ns) at 1.45v will throw an error. If this passes I'll keep tightening it up to see where it breaks. This alone should eliminate if it is Samsung C die right?
Can one successfully remove heatspreaders without damaging the heatspreader or thermal tape? Maybe with a heat gun? Would it be hard to reuse the thermal tape at that point?
Edit:
Set to 3200MHz with XMP at 1.45V and tightened tRFC to 288 and it passed anta extreme for an hour. Testing at 256 right now and then I'll work on tightening timings and see where it needs more voltage to scale.
Edit:
