Originally Posted by Tig.
Lol. Easier said than done!
This will be my first time, so it's a bit scary..
What are the normal procedures I should do?
1. Go into Bios.
2. Change multiplier up in increments.
3. Restart and test for 10 minutes.
4. Repeat 2 and 3 until failure.
4. Get mad.
5. Go back into Bios and up the voltage.
6. See if it works.
7. Keep doing this until it goes to hot (70c right?) or it won't work anymore.
8. Come back to OCN and complain it doesn't work.
Is this correct?
Heres what I do:
1. Go into BIOS.
2. Increase multiplier up by 1x up to 17x, then 0.5x afterwards.
3. Restart and run Linx @ max memory/20 passes.
3.5. If Fail, increase CPU voltage by one step (0.0125v) and try test again.
4. If OK, run Prime95 Blend test overnight (~10hrs minimum to cycle from 8k-4096k)
4.5. If Fail, increase CPU voltage by one step (0.0125v) and try test again.
5. Rinse and repeat over the entire week.
6. Record max multiplier @ max voltage.
7. Drop CPU multiplier back to stock (15.5x)
8. Increase CPU-NB Multiplier by 1x
9. Restart and run Prime95 custom test (FFT length 512k-1024k/10min) for an hour.
10. If Fail, increase CPU-Nb voltage by one step (0.0125v) and try again.
11. If OK, run Prime95 Blend test overnight.
12. Rinse and repeat for CPU-NB until you hit 13x, or 2600mhz.
13. Set max multiplier and max voltage for CPU and CPU-NB.
14. Run Linx max
[email protected] passes.
15. If OK, run Prime95. If Fail, ragequit.
