1 - 6 of 6 Posts
Hello my friends <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
I overclocked my CPU {Intel celeron 320 D-2,4 ghz} to 3,4<br>
and the temperature is 40 degrees.Is this temperature normal?<br>
With the old cpu cooler the temperature at 2,4 ghz was 60 degrees<br>
I think that is normal.
It depends on the CPU Cooler.<br />
Don't worry if it is saying anything low, as long as you know it have been saying higher (In case of temperature sensor unstability).<br />
Which CPU Cooler do you have?
I'm using cool master.It has one entrance and one exit<br>
On the entrace i've put 4000 rpm cooler and on the exit i've put 2000 rpm cooler.<br>
I have a video of my computer ,when i put music <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"> i'll give it to you.
Administrator
Those temps are perfectly safe. However your temp will be different at a load situation. Put the CPU under some stress namely a game or running Prime95.<br><br>
Load temps are the temps to go by. Idle temps dont tell you much.<br><br>
As far as it goes those temps look fine
Discussion Starter #5
This is my computer <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
Have a look at it <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><a href="http://souljah.data.bg/My%20videos/My%20cpu.avi" target="_blank">http://souljah.data.bg/My%20videos/My%20cpu.avi</a><br>
and tell me what u think
Tip: you can fill in your specs in the 'system specs' tab, so you can put something else in your sig <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
EDIT: and the link to the video doesn't seem to work.. this could be due to the very crappy pc I'm on right now (celly 1.8Ghz, 256RAM) <img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /> but just letting you know.<br />
I'll check on my own computer when I get home
1 - 6 of 6 Posts
