1 - 5 of 5 Posts
I'm struggling to find distilled water where I live. Everywhere that I ask, they just point me to some battery water and tell me it's the same as distilled. I researched this and from what I read, it seems that water for batteries is not the same as distilled and is not to be used in a water cooling loop? But, due to my difficulty in finding any other one, I thought I would just post pictures of the bottle and ask if this one is OK.
Iconoclast
Battery water should be distilled water, but I'm curious as to why there is a Ph of 6-7 listed?
Distilled water is slightly acidic, but unless it has way too much CO2 in it, it should not get down to Ph of 6.
It's probably fine, just a curious specification.
You can buy distilled water at the local grocery store. Arrowhead sells jugs of it with a pour spout.
Regards,
Steve
Posted via Tapatalk on a GS5
Regards,
Steve
In the US yes but anywhere else no lol. I have to buy it online in France only thing in stores is water for ironing which still has some impurities i believe.
1 - 5 of 5 Posts
