Is this watercooling stuff ok?
243 5
Hi,
I've been busy all day trying to figure out an compatible watercooling for my friend (CPU only) (budget €200) And I came with this
Reservoir: XSPC Singe 5.25 Bay Reservoir = €29,99
Radiator: XSPC RS120 Black = €32,99
Pump: Laing DDC-1 MPC350 12V = €66,95
Fitting (x8): 10MM EK High Flow Fiting - G1/4 Schroefdraad = 18,72
O-Rings: O-Ring for G1/4 (x8): €4,00
Hoses (x4): Masterkleer HighFlow 3/8ID - 1/2OD Transparent = €11,96
CPU Block: EK-Supreme LTX Acetal/Copper = €34,95
Radiator Fan: Yate Loon 120MM = €5,99
The CPU is an Intel Core 2 Duo on a ASUS P5QPL-AM
The case he has is not big...xD nut is this comatible and will this do?
Thanks
ShadowAS1
1 - 6 of 6 Posts
Originally Posted by ShadowAS1;14239272
Thanx for the replies
I should've mentioned that he wants custom cooling and not a corsair h70 like
thanks for the XSPC kit any idea where its available in the netherlands?
yup best kid ever had it for 3 days and happy so far you can find it at frozencou.com and the kit is 129.99 and your still under buget
1 - 6 of 6 Posts
