1 - 12 of 12 Posts
Before someone gives me a generic response, please read the following:
I currently have an LSI MegaRAID 9240-4i hooked up to a 2 TB and a Crucial C300. I have not enabled RAID in the controller either. However since its running through a RAID controller will my C300 have TRIM? Or do I automatically lose TRIM since its not directly plugged into my motherboard?
Also the result of fsutil.exe behavior query DisableDeleteNotify is 0, but I want to make sure.
Would appreciate a quick response!
"At a command prompt (start/run/cmd), type the following: fsutil.exe behavior query DisableDeleteNotify
It should respond back with DisableDeleteNotify=0 if trim support is ready and active. If it is not, type fsutil.exe behavior set DisableDeleteNotify 0
This will set Windows 7 to use TRIM when the drive and drivers are ready to do so."
source: http://www.overclock.net/8903031-post2.html
Discussion Starter · #6 ·
Thanks, but as stated in the original post the output of that is 0, I just want to make sure thats correct since its going through a RAID card.
Originally Posted by hokeyplyr48
TRIM very rarely works through TRIM, since the OS is not seeing the drive, but the "drive" that the RAID array creates.
That is what I don't get, it appears that he has only 2 drives, 1 SSD and 1 HDD, why connect them to the RAID card at all ...
1 - 12 of 12 Posts
