is wireless faster then wired?
584 Views 8 Replies 6 Participants Last post by  chickenricesoup
wireless faster then wired internet?
i have a wireless pci card sitting here claiming to be 2.4ghz/54mbps
when i installed it i can get 11mbps but thats on other ppls conection,never bothered to try to dl somthin because i couldnt figure out how to get my wireless system running plus im paying for internet and didnt see the point in using others conection
confusing?well i sure am getting confused
1 - 9 of 9 Posts
The connection is only fast as the slowest Bottleneck (Ie you package)
Your wireless card is capable of up to 54Mbps. Generally, Ethernet connections are capable of up to 100Mbps. Either way, it's limited by how fast your internet package is. Cable connections are usually 1.5Mbps-10Mbps.
Use Ethernet if you game online. Otherwise, it doesn't really make a difference.
EDIT - Look at it this way: Your wireless router is capable of running a maximum of 54Mbps connection from your ISP. If you had a 70Mbps connection coming from your ISP, then the wireless card would limit you.
Wired is always better. Only use wireless if you cant be wired because of where the cables are. A wireless connection will not make your internet faster. The 54Mbps is how fast it communicates with the router.
Even if you have gigabit ethernet, still won't download faster than your internet will go.
And 54mbps wireless? That's probably one crappy wireless card, so pretty much any LAN will be faster.
its out of an old computer
Wired, right now, is faster than wireless. Wireless is just convenient if you have a laptop, or a ton of devices that need internet; and you don't have your house wired for networking.
55 mb/s for wireless g would be in a perfect scenario with a perfect signal, while still probably not reaching it.
Even with the 55 mbps on your internal network, you would still be bottlenecked by your actual internet connection (ie, if you paid for 5 mbps downrate / 512 kb uprate, you would be limited to that speed even if you had wireless g at 55MB.
Now, most modems are 10/100mb/ps standard, which will operate at 10/ or 100 mbps. (practically everything now is 100, or even 1000 mbps for wired. (I haven't seen modems for 1000mbps yet)
If you had internet that ran at 50 mbps, you would get that 50 mbps on your wireless (in ideal conditions.
So in a nutshell, If I have some massive downloading to do, I use the rig that's hardwired, and my wireless for simple tasks like posting here
1 - 9 of 9 Posts
