1 - 7 of 7 Posts
i am becoming really impatient as i have my monitors nearly all done and my current gpu cannot support running them all so i was wondering to just buy the r9 295x2 instead of waiting,
xfx is by far cheaper than anyone else currently selling r9 295x2 from my looks by £100
have they had any bad reputation for r9 295x2?
i have heard of people having lots of issues with previous xfx amd cards so was just wondering before i would buy one
paired with what other components? psu, cpu, etc.
cpu:5820k @ 4.3ghz
ram:32gb gskill @2.4ghz
mobo:MSI X99S SLI PLUS
psu: 1250w platnium zalman
as for games any at the moment and will be used for programming
resolution
5x1 1080p monitors and 1440p overtop
so 5400x1920 resolution
New to OCN?
Originally Posted by joeh4384 View Post
All the 295x2's are the same. I think the manufacturers just relabel the fans.
probably
Originally Posted by errorlulz View Post
cpu:5820k @ 4.3ghz
resolution
Better get a pair of r9 290 the pcs+ is 220GBP at Overclockers uk and they almost are 5%-7% behing a r9 290x .it will not throttle.where the weak vrm cooling on the 295x2 will be the main problem
cpu:5820k @ 4.3ghz
resolution
Originally Posted by XAslanX View Post
I'd avoid XFX like the plague. They like to cut corners with their "custom" PCB and leave out components such as a few voltage controllers and what not, which results in questionable card life expectancy. Here is a thread where they cut back on 5770's with missing power phases and no more two way crossfire, http://www.overclock.net/t/641684/warning-xfx-5770-now-only-using-xfxs-custom-pcb/0_100
Misinformation hawaii gpus have the best cooling/noise ratio with xfx,even a DD does better job than the DirectCU or Twinforzr..
And almost all the r9 295x2 are reference design so brand has nothing to do with the quality.the only non reference is the powercolor devil 13 which is air cooled.
1 - 7 of 7 Posts
