Ok this board is getting on my nerves because I am having multiple issue with it.
1. Any psu I put on it HW Monitor is reading the 12v @ 11.88v with a Cougar PX700 and will dip down to 11.52v with a PII x820 & a GTX460 @ max voltage/overclock. But my sig rigs psu reads a stable 11.96v sometimes 11.88. And with the PX700 currently is attached to my sig rig and its above 12v constantly.
2. The mobo will shutdown randomly as I suspect that the SB on the board is running like 92-110C while the system is running. But even with a fan on it the temps dont move below 92c but is insanely hot as I can barely touch it for 1 second literally. And everything else was under 40C even the cpu @ idle and the cpu never got above 50C @ stock.
3. And if the SB is getting that hot and causes the pc to shut off instantly with no reboot or BSOD. Can this cause a hard drive to have bad clusters. Because I attached my 1tb F3 HD103SJ to it as a OS drive and now it says it has bad cluster out of no where.
Info about system and problems that it has had so far.
Amd PII x4 820 2.8ghz 4mb L3 cache
MSI NF750-GD55 mobo
Gskill 2x4gb PC3-1333mhz 9-9-9-24 T1
Cougar PX700 700watt psu
Samsung F3 HD103SJ
Galaxy GTX460 768mb
1st problem I was told it had was it would lose the video signal and wouldnt not come back with out a restart. It did that once.
Another problem was games while playing had green artfiacts and glitching while playing Diablo II and just glitching with Rift and DC Universe Online.
Last was it would not turn on one day at all after it was turned off. I have read online that this board has a problem if something is not stable it will take several times to reboot to get it back to default settings. Well problem there is nothing was changed from default at all other then turning the iGPU off.
When i tested the iGPU it said it was idling @ 64C if that helps any. Have SS I am posting below. While running Prime95 for 30mins and Kombuster on my sig rigs 9800 GT. I am going to change to the GTX460 after I post this to show any changes.
MSI NF750-GD55 mobo
Samsung F3 HD103SJ
Galaxy GTX460 768mb
