Ok so i just bought a second a 460 but cant figure out why my sli wont enable.
There both the same card, diff stock clocks but i know that should not be an issue both have diff bios also. here are the specs of both card1 is top and card 2 is bottom. any help would be awsome cause im stumped!
Do you have the SLI bridge on? Have you enabled SLI in nvidia control panel?
Yeah the bridge is on, and the sli section in control panel is not there...as its not active i guess. i have removed my old drivers a dl'd new ones also. Done as a clean install also.
Do your MoBo support SLI? The SLI option should come up in the drivers menu.
Reinstall the drivers.
Usually if you hadn't reinstall them after putting the second card and using the bridge, it sometimes bugs out and doesn't give the SLI option.
Overclock.net
