1 - 4 of 4 Posts
Hey guys.<br />
<br />
I'm running 2 sticks of pc3200 ram, both are 512mb. Both are generic sticks, but made by different manufacturers. <br />
<br />
Here is the specs from Everest:<br />
<br />
SPD Memory Modules:<br />
DIMM1 <br />
512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz)<br />
<br />
DIMM2<br />
512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-4-4-7 @ 166 MHz)<br />
<br />
Ive overclocked slightly to 2.5-4-3-8, I'm still using the factory voltage, and I've got heatsinks on both.<br />
<br />
My problem is that when I try to run them as dual channel, my system wont boot, regardless of the timings. Is this because one can be ran at the different speed, or something else that I might be overlooking?
Administrator
This is generally due to the different IC chips used on the RAM. Now the same speed and timings dont mean that they will function in a Dual channel setup.<br><br>
Have you tried resetting the CMOS?<br><br>
Remove the little battery from the motherboard for around 2mins and then put it back in and this shall reset the BIOS and will recognise the RAM again...Try that mate.
Thanks ENTERPRISE1701<br />
<br />
I dont actually have a problem of the computer not booting. It only does that when I try and run them as dual channel<br />
<br />
I think this gives me a reason to buy corsair <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 4 of 4 Posts
