1 - 20 of 33 Posts
alright guys,
system stabilized and cool! i have reached the temps and stability i have longed for, for so long! and here is the pic!
p4 1.8 @ 2.5
temps: 28-29 case!
34-35 cpu idle!
i owe it to the great people of this forum!
thanks for all the help!
Originally Posted by newbieocer
alright guys,
p4 1.8 @ 2.5
temps: 28-29 case!
34-35 cpu idle!
congratz
Awesome! Crank it up some more!!!!!
Yeah man i def. like the case setup, it makes the whole setup look excellent, inside and out... also the twin fans in the 5.25 bays, that's real inventive... excellent job all around...good job and see how far you can go with it...
alright guys,
p4 1.8 @ 2.5
temps: 28-29 case!
34-35 cpu idle!
The Duct Mod would work with that case setup!!!!!!!!!!!!!!!!!!!!!!!!
How did you mount those fans up front? Are those custom?
alright guys,
p4 1.8 @ 2.5
temps: 28-29 case!
34-35 cpu idle!
Discussion Starter · #14 ·
yeah, i know
i put a steel tube duct (air conditioning) style on the front panel to feed outside air directly to the cpu, but the temps did not change...
so i just put hte fan back on...
Discussion Starter · #15 ·
custom! yeah right!!
popped out the 2 extra 5.25 bays, super glued the two fans together,
then mounted them into the slots using a little tray method i devised.
looks decent enough, but more importantly, those 2 fans brought case temps down 4-7 degrees celcius
Sweet.. it looks awesome man. I might try that mod out to see if it cools my case down it runs hot as hell not enough intake too much blowing out. Sucks.. Did you use the old slot cover to mount them in there?
I think that's an awesome ideah... excellent innovation
sweet if you don't mind i think i might use your idea... if you mind, PM me or just post...
Discussion Starter · #18 ·
you got it!
i used the extra materials from the popping out to connect to the case
i am sure you will figure it out, such an easy mod, that is why i decided to do it, i have a top exhaust, if you don't, it might not help as much...
but i am sure it will at least something!!
drastic change for me, my temps NEVER go above 30 now
Discussion Starter · #19 ·
use and abuse my friend, hope it does the same for you...
its all about the superglue!
1 - 20 of 33 Posts
