Last time I watercooled a pc was 2003.
Its been forever but I decided to give it a shot as a hobby.
I managed to get a FT03 case and would like to have 2x r9 290.
I dont overclock. I am more into silent systems.
So the question is,
1. How much PSU is minimum? I have a HX750 but would like to know if I have to upgrade. I will most likely upgrade to AX860 or Seasonic x850 or plat
2. How much radiator is required? I know the on the bot I can fit dual 80mm and top 120mm. I think I can squeeze in another 120 mm above the power supply but would like to put pump and reservoir in there if possible.
Thanks for your help!
So the question is,
