1. if you buy an album, for example, can you delete it and then redownload it as many times as you want, like with Steam, or are there download limits?
2. what happens to your stuff if for example, you are forced to reformat?
3. is the quality of the downloaded movies good?
4. what formats do the music and movies use? more specifically, can i take them out of iTunes and then play them with VLC/WMP/player of my choice?
thanks
thanks
