1 - 4 of 4 Posts
I installed the new iTunes on a fresh install of Windows 7 and the volume is significantly lower than it used to be, I can't even see bars come up on my equalizer anymore and I could see the full range before. System sounds sound loud and normal, as well as YouTube videos, ect. but iTunes music is just lower. I've checked the equalizer, as well as reset everything to default. All bars are up on volume on iTunes and Windows, as well as making sure the iTunes mixer bar was up all the way.
Looking for some help, thanks!
Not new to Overclock.net
I recommend trying this:
  1. Open iTunes
  2. Left-click on the speaker icon in the Notification Area
  3. Click on "Mixer"
  4. Check the volume for iTunes and adjust as needed
If this doesn't solve it or change anything, then I don't know what else to try.
  1. Open iTunes
  3. Click on "Mixer"
Yeah, that's what I meant by I made sure the iTunes volume was all the way up in the mixer. :/ Thanks for the reply though.
Aw. You're welcome, though!
1 - 4 of 4 Posts
