Originally Posted by dixson01974
I also thinking of 400w peltier with a fish pond pump ( 250 gph) . Radiator with 3 120mm fans on it . Does someone know if they made a 50mm waterblock for a cpu . Peltier is for the cpu . Hey flak-spammer please post those links for the waterblocks .
To start a large number of cpu blocks are 50mm.
What's your fascination with using the radiator ...for goodness sake.
You can't mount the pelts directly on the radiator like you seem to be thinking....Scarlet has already told you that...
The setup you need is waterblocks for the coldside of the pelts then either more waterblocks for the hotside and the radiator to cool them OR as you are powering the pelts at low voltage IN THIS CASE you can use CPU fan/heatsink combo's on the hotsides, heck of a noise though.
You will need to run them at low voltage, like flak said, because the wiring setup for 8 x 136w is difficult/expensive to power unless of course you have a 110v supply then you could run them direct from the wall....but it could be risky.
Having said that of course the problem is not all waterblocks can stand the 150-300 psi pressure on the pelt needed for efficient thermal transfer.... the mounts bend too easy.
To get your CPU in the 20-25ºC range you will need to get the coolant several degrees cooler so don't put a rad in this loop as it will attempt to warm the coolant to ambient which is above your target.
It depends on a hell of a lot of factors but it is quite feasible you CPU will go even lower.
Obviously at these lower temps it's wise to insulate your system.
From the point of view of efficiency you would be better off running many pelts at low power than one big one at greater power. It would be up to you but the setup is pretty much the same.
If you use a 400w one it will probably be 62mm square (unless of course it is an ebay one then it could well be 50mm but it wont be 400w either.) and you will need to use copper plates between the waterblock and pelt because the pelt must be completely covered and most cpu blocks are 50mm square max.
If you only want to cool the CPU you are often better doing direct die but if it's your 955 that's about the max CPU I would consider. If your not an overclocker it would be fairly easy but if you plan upgrades etc a chiller might be a better option as it's easier to move from one system to another.
