1 - 14 of 14 Posts
I put a password yesterday in my other pc , but *** , today i tottaly forgot it.<br>
How can i get in again and take out the password?<br>
it was the only acount, and administrator.<br>
Really Need help<br>
()because i'm stupid!()
Boot into safe mode and see if the administrator has a password. If so then you will have to hook the drive to another computer, get your files off it, and then reinstall windows.
win xp? log in in safemode, you will see there is another account that is hidden under normal login. use it, then just remove the password from the other user account you've locked in the users control panel
if u cant log in to any user get a floppy and format it to dos boot disk. then reboot the pc with floppy as 1 drive. when you get to dos go to c:\\windows\\system32. over there there is a file called logon first backit up somewere else then delete it . again in the system 32 file copy cmd and rename it as logon. then reboot your pc a hard disk as master then when you get to login page wait for 15 min so that the screen saver comes up. instead cmd will come up type net stat administrator * into cmd and type in ure new password
Discussion Starter #6
No it's in windows 2000 pro edition.<br>
Should i do the same thing?<br>
Isn't there software to crak passwors?<br>
I really needed something simple , because i don't understand anithing about goigng in to safe mode and that kind of stuff
You can download this as well, its a linux based rescue disk that allows you to strip the password off windows accounts.<br><br><a href="http://ebcd.pcministry.com/" target="_blank">http://ebcd.pcministry.com/</a>
<div>Originally Posted by <strong>Fishie36</strong></div>
<div style="font-style:italic;">Boot into safe mode and see if the administrator has a password. If so then you will have to hook the drive to another computer, get your files off it, and then reinstall windows.</div>
</td>
</tr></table></div>
I have forgotten many passwords and always found ways of getting on w/o reinstalling. Silly fishie!!!!!!!!!!!!!<img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">
<a href="http://www.lostpassword.com/windows-xp-2000-nt.htm" target="_blank">http://www.lostpassword.com/windows-xp-2000-nt.htm</a>
Discussion Starter #10
Would this do it?<br />
<a href="http://ophcrack.sourceforge.net/" target="_blank">http://ophcrack.sourceforge.net/</a><br />
is it simple?<br />
I'm not english , and they use a bit of a complicated language....<br />
Just put the cd on tray?
Discussion Starter #11
I really need help guys .<br />
Don't let me down...
the program i gave you will be easier to use just download install then follow instructions which are pretty basic
Dude, don't try cracking it. Just reset the admin password using a linux-based password reset cd. I do it all the time, and charge people money...
Discussion Starter #14
It has been resolved.<br />
I'm sutch a noob!!!!<br />
My father had another admin acount so it was pretty easy.....<br />
thanks anyways!
1 - 14 of 14 Posts
