1 - 9 of 9 Posts
Yo OC.net<br>
I've just bought some sandpaper (Grit 180, 400, 800 and 1000)<br>
I'd like to know how I excactly should lap my heatsink?<br>
I know that I have to get some EXTREMELY flat material, and tape the sandpaper on it. How do I do then? Run in 8's? Back and forth?<br>
Also, do I have to sand it wet, and if so how do I do that?
Discussion Starter #2
Sorry, bump. I have approx. 10 minutes more to go.
I prefer to use x amount ud strokes and rotate 90 degrees.<br>
Do mark the surface with a blue or black magic marker, sand till almost all of it is gone then re mark and move to a finer grit. No need to remove all the marker indicator compleatly, the following grit will take care of that.<br>
Some like the figure 8 method, both work work so long as you keep the HS flat and square.
Discussion Starter #4
Ah, thank you! +Imaginary Rep.
Discussion Starter #5
\\o/ I lapped my heatsink!<br />
Load before: 47-53<br />
Load now: 41ish<br />
<br />
<br />
Let's do the Kirby:<br />
<('.'<) <br />
<('.')> <br />
(>'.')><br />
<tr>
<div>
Originally Posted by <strong>gonX</strong>
</div>
<div style="font-style:italic">\\o/ I lapped my heatsink!<br />
<br />
<br />
<('.'<) <br />
<('.')> <br />
(>'.')><br />
\\('.')/</div>
</td>
</tr>
</table>
</div>Nice temps, there. Now if you were really risky try lapping your cpu, oh write down your stepping and what not before you do it, don't make the same mistake I did lol.
those are some good results...and theyll get better...just wait for the thermal paste to cure...did you use as5?
Well done mate! I had to take a break doing mine as it was sooo uneven and my hand was hurting.<br />
<br />
Discussion Starter #9
Haha, I forgot to tell that I did this on my Socket A rig cooler <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
1 - 9 of 9 Posts
