1 - 13 of 13 Posts
This is a noob question I know, but im wondering about my cpu temps. I recently installed an i5 3570k with h-100 and booted it up and monitored temps for a few minutes.
My motherboard bios read between 27-28.5C . Is this normal temp?
This is with an i5 3570k, AsRock z77 extreme 4 MoBo. No pci cards or drives installed.
How many volts!?
Before I'd call for concern, I'd be looking to boot into Windows to check the temps.
Not to mention those temps are 100% fine. Idle isn't really what counts, it's more the load temps I'd be watching for.
Ok thanks. I only wanted to check with others to see if there was a potential problem I could fix before it got worse. I should be looking for around 65-70c under load right?
Have you overclocked it yet?
I have not. Ive yet to learn how. I'm just focusing on getting the build finished and running the I'll OC it.
I don't think it'll be anything near 70 celcius under load. They should be around 45-55 celcius.
OP, my ambient is around 25-27c, my 3770k idles around 32C with the h100, at 1.22v, under load (4.5ghz) it was hitting the mid 70s =/
My 3770K is running at 31-40c in idle, this is OCed at 4.5 with 1.29v... also under a H100.
When running prime it reaches 85c easy
I think your temps are fine.
To me it looks normal. Nothing unsafe or to be concerned about.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
DUDE OMG! We have the exact setup. But i have to reapply the Thermal paste cuz i have to transfer it to my new cpu. I used an MX-2 and all on stock, Bios HWmonitor reads it as 36-38c. I'm like getting 10c hotter than yours!
I use the pea method to apply the MX-2, i accidentally tap the top of the cpu where the TIM is sitting, so i kinda smudge and messed up the pea method, but I continued putting the cooler anyways. Does this has something to do with the way I applied the TIM and the reseating of the cooler, or its just my TIM aint good enough?
Discussion Starter #12
Honestly my ambient temp was like crazy low as I was working basically in a very drafty outdoor shop. Inside a building I get around 36c idle temp with ambient about 75F. So chances are that small smidge didnt make a big difference
1 - 13 of 13 Posts
