Thanks for the offer on the blade btw, but that would NEVER get through customs and I don't really need it as I've got one that works fine. Thankyou though +rep for being kind and offering.
I see you're also rocking the same board as me... What revision is it and what BIOS are you on? I can't seem to pull much speed from my Samsung memory with this board but I guess it's never been tested in anything else..
EDIT: I really hope that the IHS comes off easily.. I'm kind of scared of getting halfway and wanting to stop. I guess it'd still run fine as long as I don't dent it or anything with it half off. (Still half sealed) or if I dent the CPU... The worst case would be if I nicked the PCB of actual cores itself and either got a working 1, 2 or 3 core of a damaged IMC that can only run single channel.. That means I'd have a *spare* 8GB set of this RAM and less performance. If that's the case I might even sell it, if I destroy it I'd probably be able to convince my grandmother/auntie to replace it and say that I dropped it or something
As dodgy as that is... It'd work lol
EDIT2: I'll have to ask what type of blade that is...? Incase my blade is too thick.
Yeah, so far I've practiced with that exact blade on some old P4's that were just sitting here and have been for 2+ years. (If they've been there that long I figure why not?) and a working Celeron System is my testbed to see if the two Celerons I've had are successful, first Celeron I did had horribly dried paste that I couldn't remove, but it POSTED fine and entered the BIOS fine. I'm going to do the other one the day I do my 3570k to get my confidence up...Originally Posted by VonDutch
that "default picture" is called Avatar,
lolz
this is one of the thinnest razor blades i can think off,
if you really need/want them for delid, i could sent you some from over here,
i think i can get them![]()
practice on some old pentiums is a real good thing to do, i you can..
just to get the feeling how to cut, and...how not too ..lol
