I know 4-6c is normal, but when it's 10c+ it's not "Normal". The guy with 67c max you could push to the low 80's and be safe. That is what I plan to do, my goal really is 4.7GHz+ for 24/7 which is in the 1.42v area which is do-able with my cooler if it's working right.
Also, wouldn't it make sense if the better your cooler the bigger temperature difference you get? Because it is technically getting more performance per piece of metal/heatpipe and that would multiply if your CPU cooler was a dual tower as opposed to something like a Hyper 212+. That's how I can explain it anyway, in my head I make sense
I'm hoping for a 15-20c+ drop in temps, it'd be nice to see 30c or so as my chip is rather bad. I may have to get a new rear fan too as after this I'll need to turn my fans up sometimes.
I actually have some of that sitting here! About half a tube, I'll be using MX-2 as I can get a hold of that fairly cheap and locally though. I'll save the CF III for a better (non tempoary) case.
Nice, I plan to get one of each. The Ultra for the core and the Pro for on top of the IHS as it's easier to clean. That and shipping is the same on 2 tubes as opposed to 1. May even get 2 of each if shipping is the same.
Wow, that's crazy! It's still good to de-lid as slightly less voltage is nice and less heat on the CPU itself is better to prolong the life of the chip. I can do 4.6GHz on "stock" for 24/7 but it's pushing towards the 85c+ area and needs a fair bit of voltage. I prefer 4.4 as a 24//7 clock right now but temporarily have it at 4 as I had a few problems with black ops 2, turns out it was my graphics card wanting more voltage on the memory..
