1 - 3 of 3 Posts
My programming goes as far as C, so not far. I'm trying to help a friend with her Javascript and figured I could get some help here. Heres what she gave me.
var pos=50
setInterval ("move()",50)
function move()
if (pos>max||pos<min)
...do something
myElement.style.top=pos;
I assume the ball is supposed to bounce and come to a rest, although she never said it came to rest. She said it keeps bouncing. Anyone give me any help?
What you can do is create a direction variable that could add or subtract from the position of the ball ( pos+=direction; ). To make is simple, make this variable equal to 1 or -1. If a bounce occurs ( if (pos>max||pos<min) ) multiply your direction value by -1 switching the polarity. That should get you started
edit: forgot the semicolon
1 - 3 of 3 Posts
