1 - 20 of 24 Posts
Stopgap Fix for Critical Firefox 3.5 Security Hole
Instructions showing hackers how to exploit an unpatched, critical security hole in Mozilla's new Firefox 3.5 Web browser have been posted online. So, until Mozilla can ship an update to quash this bug, Security Fix is posting instructions to help readers protect themselves from this vulnerability.
The security hole has to do with a flaw in the way Firefox 3.5 handles Javascript, a powerful programming language heavily used on popular Web sites. Specifically, the vulnerability was introduced with the addition of the Tracemonkey, a new feature in 3.5 that is designed to dramatically speed up the rendering of Javascript.
Vulnerability watcher Secunia rates this flaw "highly critical," noting that it is the type of flaw that criminals could use to remotely install rogue software, merely by convincing users to visit a hacked or booby-trapped Web site.
Fortunately, there is a relatively easy fix for this that can be reversed once Mozilla issues a patch. To disable the vulnerable component, open up a new Firefox window and type "about:config" (without the quotes) in the browser's address bar. In the "filter" box, type "jit" and you should see a setting called "javascript.options.jit.content". You should notice that beside that setting it reads "true," meaning the setting is enabled. If you just double-click on that setting, it should disable it, changing the option to "false." That's it.
Note that making this change will slow down Javascript rendering in Firefox 3.5 to 3.0 speeds, but that may be a worthwhile trade-off for readers concerned about the availability of exploit code for this flaw.
WaPo http://voices.washingtonpost.com/sec...ss=securityfix
Title: Mozilla Firefox 3.5 Remote Code Execution Vulnerability
Severity: HIGH
Description:
Mozilla Firefox is a web browser available for various platforms.
Firefox is prone to a remote code-execution vulnerability due to an unspecified error. This issue arises during the processing of JavaScript and may present itself when certain string characters are escaped and subsequently copied to a buffer.
Successful exploits may allow an attacker to execute arbitrary code in the context of the user running the affected application. Failed attempts will likely result in denial-of-service conditions.
The issue affects Firefox 3.5; other versions may also be vulnerable.
The remote code execution was confirmed in Firefox 3.5 running on Microsoft Windows XP SP2. A crash was observed in Firefox 3.5 on Microsoft Windows XP SP3.
Affected Products:
* Mozilla Firefox 3.5.0
Source
Got this warning just a short time ago from a co-work, and found some sites to link about it; so do watch what your logged in as, and where you go.
Originally Posted by TFL Replica
Well if anyone with XP is still on SP2 AND they forgo using noscript then they deserve all the remote execution in the world.
I didn't hear about it though this source, but through more official channels, but it does effect SP3 as well as SP2.
While Noscript is great, not everyone uses it (if you are dumb enough to go to bad sites, chances are your not using something safe like up-to-date AV/Noscript). Though I don't know if Noscript would block it.. mind if I borrow your computer for a little bit to test?
Yes, common sense can cure many a problems.
Do you really think the average user knows about noscript?
PC Gamer
well i don't use Firefox for the security reason, never have, i use it because i like the user interface, i like how it has a good range of addons, highly customizable, very fast speeds
this is more a issue with Java then it is firefox tbh
Super Moderator
Don't be silly. The average user is going to get his/her "fix" of malware regardless of OS/browser software and all the security patches in the world won't save them.
Also don't troll, chrome will never match firefox.
I like chrome better. Stop trolling.
Originally Posted by TFL Replica View Post
Come on now, be reasonable, it's a Firefox related thread. Instead of using the word troll as a weapon, get back on topic.
If you hadn't noticed, you used the word troll first.
They did not say anything about Vista or 7. Is this an example of security being better on Vista/7?
Unfortunately, no.
But I'm not sure how much it would help, as no amount of technology can save idiots from themselves.
Originally Posted by vtech1
people have there own opinions on what browser to use and it is there own choice ,if everyone keeps saying this or that is better i can tell u that this thread will become locked in minutes, GROW UP!!
One thing though that isn't my opinion.
Chrome doesn't have this vulnerability, Firefox does.
1 - 20 of 24 Posts
