Just bought my first laptop !
758 Views 4 Replies 2 Participants Last post by  rams1234
HP PAVILION DV6Z
  • Espresso Black
  • Genuine Windows 7 Home Premium 64-bit
  • AMD Athlon(TM) II Dual-Core Processor for Notebook PCs M300 (2.0GHz, 1MB L2 Cache)
  • FREE Upgrade to 4GB DDR2 System Memory (2 Dimm) from 2GB DDR2 System Memory (2 Dimm)
  • FREE Upgrade to 320GB 5400RPM SATA Hard Drive from 250GB 5400RPM SATA Hard Drive
  • ATI Radeon(TM) HD 4200 Graphics with 128MB Display Cache Memory
  • 15.6" diagonal High Definition LED HP Brightview Widescreen Display (1366x768)
  • LightScribe SuperMulti 8X DVD+/-RW with Double Layer Support
  • Webcam Only
  • Wireless-G Card
  • HP Color Matching Keyboard
  • 6 Cell Lithium Ion Battery
  • No Modem
  • HDMI
  • 4 USB
  • Microsoft(R) Works 9.0
  • HP Home & Home Office Store in-box envelope
If everything works out with my bing cashback, my final price would be about $477. I also got 6 months - no payments. What do you think ?
1 - 5 of 5 Posts
grats
seems pretty good for the $
It was hard for me to buy an AMD computer as I have always used Intel. I hope I like it. I got screwed on the same HP series computer on black friday from Staples. The only difference is after rebates I would have payed $437. So this one is $40 more. BUT has the AMD m300 instead of Intel T4300, 320gb hard drive instead of 250gb hard drive, and ATI 4200 HD 128mb graphics instead of Intel 4500 MHD graphics. So I hope I got a good buy. HP had $150 instant rebate, plus I should get $25 back for using Bill my later, plus I should get about $110 back from the Bing 20% cashback.
IF you get all your rebates, then i'd say you got a screaming deal
What is this Bing 20% cashback youre talking about?
Now HP is having their cyber monday sale. The core 2 duo version got cheaper. I wonder if theres any way to switch my order. With the cashback and everything I think it would only come out to $42 more to have the core 2 duo T6600 instead of AMD M300 and 4gb DDR3 instead of 4gb DDR2. The only downgrade is going from ATI 4200 HD to the Intel 4500 MHD graphics. You think I should see if I could switch for about $50 more? Better chip, faster ram with less graphics?
Bing.com - microsofts search engine. If you enter certain stores through their search engine, they offer different amounts of cashback on your order. HP is 20% now. Pretty high.
1 - 5 of 5 Posts
