1 - 20 of 82 Posts
firstly, check inside the case to see if there are any loose connections. Make sure the 4/8 pin cpu plug is connected to the mobo, make sure ram is in all the way, and the 24 pin mobo connection is in all the way.
Well make sure that the CPU fan is connected to the CPU fan header because the BIOS will shut down the system if it thinks there isn't a CPU fan running. Check the power connections on the mobo 24, 4-8 pin. Also check if there is a connection for the video card you're using.
the 4pin is the One near the cpu right, yeh it is plugged in... and the 24 is Pluged in all the way...
yeah it is the one near the cpu. Ok then, make sure that all other connections are in place correctly as well, i had an issue like this cuz one of my ram sticks wasn't completely in all the way, could literally be something minute as that.
whats that...?
this picture down. They are the things that usually are there on the interior of the case, you screw the mobo onto these so there isn't any kind of current or charge that can harm your computer (they prevent that).
Originally Posted by lastmemory
Did you forgot to put on the standoffs?
Well, I think standoffs are the problem. Did you screw in standoffs into your case to rise the motherboard off the case to prevent shorts?
It's a common mistake for first time builds.
You ahve to use the little standoffs. You're motherboard is shorting out, because it is touching the metal case, install the risers by taking out the motherboard and putting those in the place where the screws would be, then screwing into the risers. You're computer should work fine after that.
they were in the pack of chassis screws where do they go...?
If you look at the inside of your case with the motherboard taken out. You will see a bunch of screw holes that match up with the similar pattern of screwholes on your motherboard.
You place the risers in these screw holes. This "rises" the motherboard off the metal in the case.
After that you then put your motherboard in and line it up with the risers you put in. Place screws inside the holes and this will secure the motherboard in the case
Hope you didnt short your motherboard out completely though!
1 - 20 of 82 Posts
