1 - 4 of 4 Posts
i just reformated and it only shows 127 how do i get it back to 250???
Maybe when you formatted your hard drive you created a single partition with only half the space... Either format it again or use a partition tool.
HAve you installed SP2 yet? If not install it. Or if you have, right click mp computer, go to manage, then disk managment. You un used space should show up black. If you right click the black space you have the option to re claim you space, I forget what it's called though.
Discussion Starter #4
thanx for helping me fix the problem
1 - 4 of 4 Posts
