1. Keep 140mm as exhaust.
2. Yes, removing grills should make a noticable difference in noise and performance
Originally Posted by Chucko ![]() It helps a lot if you can soft mount the fans. That 140mm fan vibrates a bunch. That vibration is a much bigger issue than the air turbulence noise from the fan grate. |
