1 - 3 of 3 Posts
got my new DSI
1. need some game recommendations
2. i had to be stupid and not check the charger before so i can't use it... it's a 110V and i'm 220V, if i can't find a cheap cable can i hack the charger and use it with a USB header?
3. i'm new to the whole DSI thing, anything can help me
4. if you know good sites and forums for DSI for noobs like me it will help
Really enjoying Zelda: The Phantom Hourglass at the minute. No doubt Spirit Tracks is good too. Depends on what you like.
I wouldn't recommend "hacking" the charger, this would put your shiny new warranty at risk... find a 220v cable.
General DS advice, I'm sure you're aware of the 'cards'...
http://www.overclock.net/nintendo/88...lite-card.html
I recommend the Acekard 2i but be aware of fakes and buy from an approved reseller.
don't worry, no warranty anyway, i got if from a forum member
i already have the Acekard 2, not i
1 - 3 of 3 Posts
