1 - 12 of 12 Posts
Originally Posted by franz;13103461
I am running 12awg to my CS2, but I admit its overkill for such a short length of wire. I had some extra lying around, so I used it. You will be fine with any 16awg.
so if my klipsch was 14awg and i used a 16awg or 18awg to splice, i'll be fine?
thinking about getting these tonight
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023903&p_id=2822&seq=1&format=2
or
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023903&p_id=2749&seq=1&format=2
· Once more into the Fold
Originally Posted by franz;13104147
Oh I see what you mean by pigtail. Yeah you could solder the new wires to the pigtail and run them to your receiver or use a butt connector if you cant solder. Then run your CS1 with the new wires.
yep that's what i plan on doing... there are various ways to do it, but the easiest way is to use electrical tape.. not very efficient but does the job..
and butt connectors? hmmm never heard of em.
Originally Posted by FearSC549;13105245
How long are you going to be running the wires? Also, wires aren't special, so don't go out and unload your wallet on Monster cables or any unreasonably expensive cables. I'm loving my $1 25 feet 16AWG copper/nickel cables.
where do you get those from , i just bought the onkyo s6300 at amazon for 486 . i was gonna do seperate but the receiver alone was 400 bucks so i pay 86 more for the 7 speakers , i need some 16gauge later , was thinking home depot or something
Discussion Starter · #11 ·
maybe 10-20'.... the lowest monoprice has is 50', but it's still fairly cheap
1 - 12 of 12 Posts
