1 - 20 of 149 Posts
I have to say it is quite nice. One thing I was just playing with it there is a CPU frequency scaling monitor. Which basically lets you run your processor at full speed or at a lower speed. Can run my 2.4 at full speed, 2.2,2.0.1.8, or 1 ghz. You do notice a big difference in speed. While it being at 1GHz takes about 3-4 secs to open, but at full speed, it opens instantly, but for some reason my internet does not work, and me not being linux guru am having problems getting it to work. But this is worth the downhload, even if it akes a couple of hours, or a day or 2. Just MO
I have yet to even look at everything on here.
Got internet working. Apparently it deactivates the ethernet ports by default.
Nice... I'll be getting that very soon.
Discussion Starter #4
runs smooth and fast, but like I said, I am not that good at linux, so don't really know what I am doing. Trying to get the flash player 9, but keeps saying I don't have permission to write to the folders.
i think / should be bigger (i'm no Linux expert AT ALL tho). Hmm... For installing flash, i think what you gotta do is like go in the flash folder, then right click on an empty space and go to "actions" and "open terminal here." Then find a file named something like "install-flash-player" and type this in:
./install-flash-player
Then it'll ask you some questions before installing. That is the ONLY piece of software i ever got installed successfully under ANY Linux. It's difficult for the beginner (like me lol)
K092084, are you using sudo to install flash?
Originally Posted by K092084
Which should I make bigger, the "/" or the "/boot" when I install this?
Do you only far one partition (/) or many(/home, /urs, etc).
There is no flash player 9 for Linux only 7. If you want 9 you'd need to run it and firefox(windows version) through WINE, and that doesn't always work.
And to install most things you'll need to be root, just add "sudo" in front of the command.
Yeah, there is a flash 9 for linux, I believe it's beta though. The_Jester told me about it.
http://labs.adobe.com/downloads/flashplayer9.html
K092084, could you by chance tell me what ethernet adapter your using, as in what model?
Discussion Starter #10
CH13f121 - don't know what sudo is. The ethernet are the onboard nforce port on the board. Why is this important, I already got the internet to work, unless need for other reasons.
Hobo - I did only 2 , the / and the /boot. I was just wanting to try it out. I am gonna have to go and resize my partitions, This is when it sucks to have multiple HDs.
Discussion Starter #11
Ok, well I am gonna resize my partitions right now, How many do I need for fedora and how big?
That is freaking sweet. I had always hear they just were going to skip flash 9 for linux and wait for the next.
Take a look at the partitioning guide here
I usually make an extend partition and then a bunch of logical one inside that.
/ - 6gb
/boot - 512mb
/swap - 2000mb
/usr - 10gb
/home - 25gb
or you can just make like this
/ -30gb
/boot 512
/swap - 2000mg
Reactions: K092084
Discussion Starter #13
/ -30gb
/boot 512
/swap - 2000mg
Probably do this, because I have set a 60gb partition that I am gonna use for it. So the boot doesn't really have to be big?
Old Timer
To install somthing when it says you dont have permision, you install it as "root", or the administrator account. To do this in FC6, ether type su - and type in the root password, or type "sudo" before each command.
"su -" will make you root for EVERY command you type durring that terminal session, so it is advisible to use "sudo" so you dont screw somthing up with out meaning too.
no, 512mb is good enough, don't go smaller though. and make sure to put it towards the beginning so its not past the 1024 cylinder range.
Discussion Starter #16
Problem with that, I am dual booting with windows, and the windows partition is on that cylinder.
As long as its at the beginning of the entended partition it'll be fine.
Discussion Starter #18
Ok, it put there automatically. It finished installing, and I am using to reply right now. But the CPU frequency scaling doesn't work this time though. Also the desktop effects don't work either.
1- Sudo is Super user do, it lets you run as root for one command.
2- I want to know waht NIC your using, because I have an RTL8168 taht has problems working in FC6
Discussion Starter #20
Ok, well FC6 is reading it as nVidia Corporation MCP55 Ethernet.
Don't know if this is just me, but I can not find the freaking terminal at all. NVM. I am a moron.
1 - 20 of 149 Posts
