1 - 4 of 4 Posts
Originally Posted by CULLEN
you can see TRIM is enabled by:
Click on Start Orb > Type "CMD.exe" in Search box > Right click on "CMD" and select "Run as Administrator" (If you receive a prompt confirmation, click YES)
fsutil behavior query disabledeletenotify
DisableDeleteNotify = 1 (Windows TRIM commands are disabled)
DisableDeleteNotify = 0 (Windows TRIM commands are enabled)
To enable trim: fsutil behavior set disabledeletenotify 0
To disable trim: fsutil behavior set disabledeletenotify 1
1 - 4 of 4 Posts
