Just lapped
626 8
Check it out!! Just lapped my Freezer 64 last night!! First time lappin', dropped my load temp 2c and idle temp 4c!
Attachment 19187
Attachment 19188
Next is the AC Silencer 6 for the 6600GT
Attachment 19189
1 - 9 of 9 Posts
Nice and shiney! No before pics?
Originally Posted by metalman2785
Nice work, what grain papers? Also did you use an alumina micron solution to finish it?
I used, 400, 600, 1500, 2500. Not sure if what i used to finish it was that type of solution, just rubbed the snot out of it with a buffing compound.
Ha, ya i didn't take one, was too excited to try it out i guess! Actually it didn't look as "rough" as i thought it was after i clean it off. So i didn't think it would be much. It looked about like the AC6 there before, a little more of a machine finish though.
Very nice lapping, usually the final solution for buffing is either an alumina or diamond micron solution. Definitely a great way to shave a few degrees of your cpu temp, good luck with the VGA cooler.
Thanks! Yeah, I put the stock cooler back on while I worked on it, and it read 52c for load! Put the "Freezer" back on after lapping and it dropped to 39c! Which is 2-3c better than before the lapping!! The VGA cooler isn't going to be easy though, it has pins in the way.
1 - 9 of 9 Posts
