1 - 8 of 8 Posts
· Premium Member
Hi there,
Just out of interest, do any of you wear gloves (latex) when building rigs? I'm putting together my first water cooling loop this weekend and have a bit of EK CSQ and wanted to avoid fingerprints and such.
Do you?
· Eh, Wha?
no, I just clean everything off when im done. The gloves would honestly be useless considering how frequently my hands get cut up to hell every time I'm doing a "nice" build due to the inevitable sharp objects and necessary fine motor control in small areas at odd angles. All it would do is make stuff harder to work with.
You could I guess do that. But I never wear gloves, not even a static band. ...knock on wood, heer I mean steel.
· Iconoclast
I often wear gloves when working with things that are best kept clean, including water loops. The cleaner your loop the longer it will last.
I use gloves whenever I'm going to be physically removing a component that plugs into a socket on the motherboard. Also come in handy applying TIM if you like to spread it a little with your finger (as I do). Just slip off the gloves when you are done and voila all clean and tidy (also keeps oil and skin grease from contacting purified surfaces, dust, etc).
I wouldnt go out of the way to buy gloves strictly for pc building but having a wife who is a medic, we typically have boxes of them laying around so I figure why not.
· Premium Member
Discussion Starter · #8 ·
Yeah I don't plan on going out of my way but my dad always has some on his work van so I'll probably grab a pair for when I do my loop.
1 - 8 of 8 Posts
