just redid cooling setup
419 Views 10 Replies 6 Participants Last post by  TeenAgeReneGade2316
so i redid my fan setup, ( x2 120mm, x2 85mm, x1 90mm ) and played three levels of COD4MW and was wondering do these temps look right to you?
fyi- the min value temps are my idle temps and the max values are under load. the current value (far left) is my rig directly after leaving a game and returning to desktop.
the GPU temp kinda scared me but i know GPUs are always hotter than h3ll. btw lowered my gpu idle temp from 140 F to around 115 F! yay!
1 - 11 of 11 Posts
opinions/help earns +REP guys come on why do i have to bribe to get responses
Looks good the only thing that looked a tad off to me was the graphics card max temp
what do you think the max should be?
well my cpu idles ~40c loads in the 60s my GPU idles 55 loads 70s looks good to me both with pretty high overclocks
EDIT: My stock idles were about the same but then only idled 50c
mine are stock lol
im not really sure what the usual temps are off hand but i googled around and found some saying that around 75-80 is the usual so i sappose its not that high, but one of the forums i found an answer on had his 40idle 70load and in those ranges seamed to be the norm
81°C for a 7800GTX isn't enough to do any damage whatsoever. If I recall correctly from when I was shopping around for a GPU two years ago, the maximum temp for the 7800 series was 90°C.
If it makes you feel any better, I've had an x1900xtx at 119°C and it didn't stop operating for another year and a half.
it looks good man my 8800gt would go over that no problem just keep it under 90C.
That's very normal you have there, how are your fans setup exactly?
thanks for the help guys, wasnt sure on the max temp for my gpu...now i know, thanks alot!
1 - 11 of 11 Posts
