1 - 1 of 1 Posts
Hey,
I've been having this annoying problem where my computer would shutdown randomly, with no warning whatsoever. There's no real pattern to the reboots, they can happen whilst gaming,
but more often than not the reboots occur when just surfing the internet.
I've ran MemTest86 for around 8 hours, there were no errors. I've also ran Prime95 for around 12 hours previously and again no errors. I'm certain it's not the GPU as I've been having the problem before I replaced both my 6970s with a single 680 and still have the issue. I'm also fairly certain it's not the CPU, I've reset my oc to factory defaults and I've still faced the same problem. I recently upgraded to Win8 from Win7, that didn't solve the issue either. I'm currently running out of ideas of what could be causing the issue and it's incredibly frustrating finding that my computer has restarted after getting a drink...
The error log is as followed:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 02/03/2013 22:12:23
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: HomeG-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
'vent Xml:
Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
System>
Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
EventID>41
Version>3
Level>1
Task>63
Opcode>0
Keywords>0x8000000000000002
TimeCreated SystemTime="2013-03-02T22:12:23.622309400Z" />
EventRecordID>2935
Correlation />
Execution ProcessID="4" ThreadID="8" />
Channel>System
Computer>MeganFox-PC
Security UserID="S-1-5-18" />
/System>
EventData>[/QUOTE]
Data Name="BugcheckCode">0
Data Name="BugcheckParameter1">0x0
Data Name="BugcheckParameter2">0x0
Data Name="BugcheckParameter3">0x0
Data Name="BugcheckParameter4">0x0
Data Name="SleepInProgress">0
Data Name="PowerButtonTimestamp">0
Data Name="BootAppStatus">0
/EventData>
/Event>'
System Specs:
i7-2600k Quad Core (@ 4.60GHz)
1TB WD CAVIAR BLACK @7200rpm
CORSAIR 1000W PRO SERIES
2GB NVIDIA GEFORCE GTX 680
Windows 8 64-bit
Sound Blaster X-Fi Xtreme Audio
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz
Thanks for the help!
1 - 1 of 1 Posts
