1 - 10 of 10 Posts
Exactly what is a Killcoil for?
Thanks.
Originally Posted by rpgman1 View Post
It's a biocide to prevent the growth of algae in your loop.
Thanks.
No problem. It seems that our experts are gone for the day.
Originally Posted by Pavo View Post
Killcoil is just a name for a silver piece in your loop, usually shaped like a coil (spring), hence the name.
Basically any piece of silver (99%) will do. Silver naturally prohibits bacterial growth.
Hope that helps
Just make sure it's labeled as 0.999 fine silver and not sterling silver.
If killcoils are too expensive, try eBay. I would recommend something like this.
Reactions: xdanisx
Originally Posted by emeianoite View Post
I think the longer you use that water, the more biocide agents are released
You are correct in that the silver ion's are slowly and continually released into the distilled water and act as a natural biocide to prevent the growth of algae. On the other extreme, if you never changed your water, enough silver ions would leach into the water to slowly deposit black on your blocks and begin to discolor the water black with silver ions. This would take a very long time and almost everyone will have probably changed their water and or rig before this would become a problem.
1 - 10 of 10 Posts
