1 - 7 of 7 Posts
hey there,
so i've bought the SSD, assembled everything, everything's blazing fast, but i started getting "hang ups" for a minute or two from time to time.
so i've identified the source.
i've tried moving the ssd to another SATA, or whatever.
i do also have an older Kingston ssd, which works just fine.
btw i've cloned the system from an hdd to ssd.
501
615
as you can see, it's 16kb/sec, which is awesome and kind of thousand times less than others do get.
the whole system just stops responding.
specs
win7 64bit professional SP1
amd 1090T
8gb kingston hyperx 1600 ram
GA-MA770T-UD3P gygabyte motherboard (F12 Bios)
No time to run a bench tonight myself but I've noticed that you are getting about half the speed I'm getting. (Read and write) Did you set drive to ACHI in bios before installing OS?
well it's sata2 controller, so half-the speed is okay i think, the problem is reads/writes of 0.5k-8k blocks of data (second screenshot). they just hand the system completely.
from what i've seen in the benchmark it's usually 15 000 not 15 :|
ahci is set (it's like 'msahci' ok in AS SSD)
just to make sure. did you set ahci both in BIOS and inside Windows?
yup, it's set inside bios, it was set upon win7 install AND, i've double cheked the registry entries.
Storage Nut
Secure erase and reinstall....
nah reinstall is not an option. by the way had to instal AMD AHCI driver instead of ms one. seems like now the speeds are okay.
thanks everyone
1 - 7 of 7 Posts
