Hello,
i recently aquired the Kingston KC1000(H) 480GB, PCIe 3.0 x4 (SKC1000H/480G)
https://geizhals.at/kingston-kc1000-h-480gb-skc1000h-480g-a1649511.html
As mobo I'm using the GA-X58A-UD5 (rev. 2.0)
https://www.gigabyte.com/Motherboard/GA-X58A-UD5-rev-20#ov
I want to use it to install and boot Windows 10 on it.
As some can imagine I realized very quickly that it does not simply work.
Since one week I'm not trying to find out if and how it could work but I'm just arriving all the time at dead ends.
At least dead ends for me due to my lack of knowledge of the things I'm trying to do.
What I think to have found out is that the core problem is to get NVMe support.
I've tried to get that by using DUET
created a USB according to this guide and found my personal dead end on a screen looking like this:
ABCD
♪ Welcome to the EFI World!
Nothing else happening...
Than I tryied to get NVMe support via CLOVER.
Created a USB-stick with BDU and arrived at my dead end after bios booting with a simple "6_" on the screen.
Now finally my question is if it will be even possible to run the KC1000 on my X58 mobo and if yes if you see any chance that I can manage it to chieve it.
If more informations are needed jsut tell me.
Thanks very much in advance.
ABCD
