1 - 5 of 5 Posts
I was wandering which would be better for TV, Movies, and Gaming. The Klipsch would have the upgraded Monster Wire kit. If there are ANY other speakers that are 5.1 and you think are better for the computer please point them out to me.
I have the Klipsch, and I think the klipsch are better for gaming.<br><br>
I believe the Z-5500 just have more hook ups so you can hook them up to your TV and stuff, but they don't sound as good. (Not 100% sure on that..What a best buy rep told me...)<br><br>
Go with the Klipsch, you won't be disappointed.
I vote for the Pro medias over the Z-5500's<br><br>
Also take a look at the <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16836116013" target="_blank">Creative Giga works G550</a>
Discussion Starter #4
Im looking at any 5.1 speakers so any thing up for grabs. I plan on using these with either a TV Tuner or a HDTV Cable box connected to my new 20.1inch LCD. So I just want the overall best speakers. I have heard that the Klipsch are better then the Logitech speakers so I am just checking.<br><br>
How about the Klipsch ProMedia Vs the Gigaworks G550 Vs Logitech Z5500?
I would say get the Klipsch system, horn tweeters are second to none.<br><br>
pink
1 - 5 of 5 Posts
