2. They do have matte screens and they are very light. Many have opted to get matte with no regrets
3. there is no calibration so you will have to calibrate the colors or use a posted color ICC profile. There is a brightness setting
5. The monitor stand has no adjustments except for a very slight tilt. You may want to look at an aftermarket stand. Many very good stands have been posted in the club thread for the Qnix for around 20-30
6. Yes backlight bleed can be an issue but there is a known fix for this in the club thread as well.
THIS IS A LOTTERY THING. A lot get very lucky but there is some bad cases. PLEASE go onto the Qnix monitor club thread and carefully and comprehensively read through AT LEAST the OP before purchasing. Most of your questions are addressed and some answered in glorious detail. Also searching in the thread is very easy if you use good search terms(backlight bleed, guide, experience, etc)
Hope you learn a bit and make an informed decision.
1. NO but some have gotten it to work at 720p
