1 - 1 of 1 Posts
Took the plung and fitted the kraken g12 along with an Asetek 240mm 570LXL cooler. Fitted without too much issue. Not a huge jump in overclocking but massive reduction in sound and temps are a good bit lower (45-50 v 72-75). I'm using coolermaster jetflo fans in a push config.
This is the kit https://www.overclockers.co.uk/ocuk-tech-labs-240mm-kraken-extreme-vga-cooling-upgrade-bundle-advanced-black-shroud-bu-084-tl.html
Can leave the back plate on and just remove the four screws holding the cooler on
The pcb without the cooler
With the brackets attached
And in the case. It sits on a cooler master vertical card holder
And my superposition score
1 - 1 of 1 Posts
