1 - 2 of 2 Posts
I thought it might be a good idea to ask here regarding which would be better?
I'm looking for good performances and if possible low noise level (or as quiet as possible) to cool an overclock 6770k in my next rig... I'm also open to suggestion regarding fan replacements to the original ones coming with the kits (or any other suggestions for anything else).
Thanks!
Call me VSG
The "Extreme" is not part of the product name as much as it is a tagline to signify "Extreme Performance" relative to other Corsair CLCs. The NZXT Kraken x61 and Corsair Hydro H115i are both built by Asetek based off the company designs, and there's really no tangible difference aside from the fans (which are close to each other too). If you must go CLC, I would recommend the H110i from Corsair/CoolIt instead. At this price point though, consider also other coolers such as the Swiftech H220-X and H240-X. Long term reliability/customer support may not be as good, but you do get better performance at similar noise levels.
1 - 2 of 2 Posts
