1 - 6 of 6 Posts
Ultimate Rig Winner
I plan on buying one of these for my next build, budget is low atm so I will this as it is supposably the same as a H60. Later in the year I may consider fitting another rad and a res, Could this be achieved with a bit of modding? I want to get eventually into WC and I think that modding something like this would be an inexpensive way to do so
Ultimate Rig Winner
Would a aftermarket pump be able to worth alongside the integrated one? This way it would allow for expanbiltyn like so...
Original --- +1 Res --- Replace rad with dual rad --- +1 pump --- CPU block
Would this work?
I think it is, but those pumps are usually weak and probably shorten it's life.
no not unless both pumps were the same. you could bypass the oem one too, but now in the end yours spending more than just going 1/2" from the start
1 - 6 of 6 Posts
