1 - 1 of 1 Posts
Hello I am trying to decide the best COA for upgrade path to get VT-d support.
Current rig:
4770k @4.5ghz
16GB RAM
SATA III
The upgrade path here would be to a 4790K which would cost around $280 and gives roughly 11,245 internet points at stock
The other option is taking a dual 1366 socket motherboard and use it with new cpu ram and heatsinks:
Dual X5675 ES @ 3.06Ghz
24GB ECC Reg RAM
SATA II (only 1 PCI-E x16 G2, though I think there is an x8 onboard as well for 2nd raid controller)
This would cost $460 and yields 13198 internet points at stock
Which would be the best upgrade path? The second method gives me a spare machine for future use but the 4790k route would be simpler.
Thanks,
1 - 1 of 1 Posts
