I have an L440GX+ Server Board that i am trying to get up and running can someone tell me what i am doing wrong? first i put board in case then hook up a hard drive and cd drive both on the same ide cable cd drive hooked up as secondary both drives pins are set to cable select. I hook up the power supply the users guide for board says i need (300w recommended)and i put in a linux server os cd and booted it up. It started cycling(no display) so i shut it down and pulled all the l.e.d. wires and reset sw wire but left the power sw wire. I turn it back on and i get a display "SERVER BOARD by intel" and then it goes on to say processor 1 failed, processor 2 failed, processor 2 disabled and at the bottom it says F1 to resume so i hit that it processes some stuff and then says OS not found among other things such as fix the date and time. I then shut down my computer and pulled the processors and reinserted them to make sure they were firmly in there and rebooted, the monitor light turns on but no display. What did i do and how do i fix it? my goal with this machine is to set up an nfs server or prob just run Gftp off of it and have REstore linux server installed on it. but for right now i want to install the os and i have no idea how can someone help me please thank you!
p.s. i dont know if this matters but the cd light is on all the time and if i leave it on long enough it starts blinking, is this a code or something the comp is trying to tell me?
